vserver show-protocols
Show protocols for Vserver
The vserver show-protocols command displays the running protocols on a given Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver
If this parameter is specified, the command displays the allowed set of protocols for the specified Vserver.
- [-protocol {nfs|cifs|fcp|iscsi|ndmp|nvme|s3}]- Protocols
If this optional parameter is specified, the command displays all the Vservers configured with the specified protocols.
The following example displays the protocols configured for Vserver vs1.
cluster1::> vserver show-protocols -vserver vs1 Vserver: vs1 Protocols: nfs, cifs
 PDFs
PDFs
