vserver show-protocols
PDF of this doc site
Creating your file...
Show protocols for Vserver
The vserver show-protocols
command displays the running protocols on a given Vserver.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
If this parameter is specified, the command displays the allowed set of protocols for the specified Vserver.
[-protocol {nfs|cifs|fcp|iscsi|ndmp|nvme|s3}]
- Protocols-
If this optional parameter is specified, the command displays all the Vservers configured with the specified protocols.
The following example displays the protocols configured for Vserver vs1.
cluster1::> vserver show-protocols -vserver vs1 Vserver: vs1 Protocols: nfs, cifs
