vserver vscan enable
Enable Vscan on a Vserver
The vserver vscan enable command enables Vscan on a Vserver.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver on which you want to enable Vscan. The Vscan configuration must already exist.
The following example enables Vscan on Vserver vs1.
cluster1::> vserver vscan enable -vserver vs1
cluster1::> vserver vscan show -vserver vs1
Vserver: vs1
Vscan Status: on
