The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nvme subsystem delete
PDF of this doc site
Creating your file...
Your file is ready
Delete the subsystem
The vserver nvme subsystem delete
command deletes an NVMe subsystem from a specified Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-subsystem <text>
- Subsystem-
Specifies the NVMe target subsystem.
[-skip-mapped-check <true>]
- Skip Mapped Namespace Check-
Required to delete an NVMe subsystem with attached NVMe namespaces.
[-skip-host-check <true>]
- Skip Host Check-
Required to delete an NVMe subsystem with associated hosts.
cluster1::*> vserver nvme subsystem delete -vserver vs_1 -subsystem sub_1
Deletes the NVMe subsystem sub_1
on Vserver vs_1
