vserver nvme subsystem delete
- PDF of this doc site
Creating your file...
Your file is ready
Delete the subsystem
The vserver nvme subsystem delete
command deletes an NVMe subsystem from a specified Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-subsystem <text>
- Subsystem-
Specifies the NVMe target subsystem.
[-skip-mapped-check <true>]
- Skip Mapped Namespace Check-
Required to delete an NVMe subsystem with attached NVMe namespaces.
[-skip-host-check <true>]
- Skip Host Check-
Required to delete an NVMe subsystem with associated hosts.
cluster1::*> vserver nvme subsystem delete -vserver vs_1 -subsystem sub_1
Deletes the NVMe subsystem sub_1
on Vserver vs_1
