ONTAP commands
vserver nvme subsystem delete
Delete the subsystem
The vserver nvme subsystem delete command deletes an NVMe subsystem from a specified Vserver.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-subsystem <text> - Subsystem
Specifies the NVMe target subsystem.
[-skip-mapped-check <true>] - Skip Mapped Namespace Check
Required to delete an NVMe subsystem with attached NVMe namespaces.
[-skip-host-check <true>] - Skip Host Check
Required to delete an NVMe subsystem with associated hosts.
cluster1::*> vserver nvme subsystem delete -vserver vs_1 -subsystem sub_1
Deletes the NVMe subsystem sub_1 on Vserver vs_1 .
