security login publickey show
Display public keys
The security login publickey show command displays information about public keys.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Selects the public keys that match this parameter value.
 [-username <text>]- Username-
 [-index <integer>]- Index-
 [-publickey <certificate>]- Public Key-
 [-fingerprint <text>]- Hex Fingerprint-
 [-bubblebabble <text>]- Bubblebabble Fingerprint-
 [-comment <text>]- Comment-
The example below displays public key information for the user named tsmith.
cluster1::> security login publickey show -username tsmith UserName: tsmith Index: 5 Public Key: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAIEAspH64CYbUsDQCdW22JnK6J /vU9upnKzd2zAk9C1f7YaWRUAFNs2Qe5lUmQ3ldi8AD0Vfbr5T6HZPCixNAIza FciDy7hgnmdj9eNGedGr/JNrftQbLD1hZybX+72DpQB0tYWBhe6eDJ1oPLob ZBGfMlPXh8VjeU44i7W4+s0hG0E=tsmith@publickey.example.com Fingerprint: 07:b4:27:52:ce:7f:35:81:5a:f2:07:cf:c1:87:91:97 Bubblebabble fingerprint: xuzom-nelug-bisih-nihyr-metig-kemal-puhut-somyd-mumuh-zomis-syxex Comment: This is a new key
