ONTAP commands
security login publickey show
Display public keys
The security login publickey show command displays information about public keys.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the public keys that match this parameter value.
[-username <text>] - Username
[-application <text>] - Application
[-index <integer>] - Index
[-publickey <certificate>] - Public Key
[-fingerprint <text>] - Hex Fingerprint
[-bubblebabble <text>] - Bubblebabble Fingerprint
[-comment <text>] - Comment
[-certificate <certificate>] - Certificate Associated with Public Key
[-certificate-details <text>] - Details about the Certificate
[-certificate-expired <text>] - Expiry Status of Certificate
[-certificate-revoked <text>] - Revocation Status of Certificate
The example below displays public key information for the user named tsmith.
cluster1::> security login publickey show -username tsmith
Vserver: vs1
UserName: tsmith Index: 5
Public Key:
ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAIEAspH64CYbUsDQCdW22JnK6J
/vU9upnKzd2zAk9C1f7YaWRUAFNs2Qe5lUmQ3ldi8AD0Vfbr5T6HZPCixNAIza
FciDy7hgnmdj9eNGedGr/JNrftQbLD1hZybX+72DpQB0tYWBhe6eDJ1oPLob
ZBGfMlPXh8VjeU44i7W4+s0hG0E=tsmith@publickey.example.com
Fingerprint:
07:b4:27:52:ce:7f:35:81:5a:f2:07:cf:c1:87:91:97
Bubblebabble fingerprint:
xuzom-nelug-bisih-nihyr-metig-kemal-puhut-somyd-mumuh-zomis-syxex
Comment:
This is a new key
Certificate:
-----BEGIN CERTIFICATE-----
MIICHTCCAaKgAwIBAgIUU+YJjeaOzvs+w+56JSm8Amow0nAwCgYIKoZIzj0EAwIw
RTELMAkGA1UEBhMCSU4xCzAJBgNVBAgMAktBMQwwCgYDVQQHDANCTFIxDTALBgNV
BAoMBE5UQVAxDDAKBgNVBAsMA1ImRDAeFw0yMjA5MjAwNjAyNDRaFw0yMzA5MjAw
NjAyNDRaMEUxCzAJBgNVBAYTAklOMQswCQYDVQQIDAJLQTEMMAoGA1UEBwwDQkxS
MQ0wCwYDVQQKDAROVEFQMQwwCgYDVQQLDANSJkQwdjAQBgcqhkjOPQIBBgUrgQQA
IgNiAASbaxCYB6XRDOFgdHBghvMoUpideGnd2jNrQJANeSaWVMnPUpXzg2tcPnsu
c87AR75BcfwhSurrFGLIw7TLcR22IFTggcrKmhjI8QwvomMZWfIoeHZlwsI+msm4
PLyaCqmjUzBRMB0GA1UdDgQWBBREeGdLZ3YTEL4CXLvTa8XQRAhRqDAfBgNVHSME
GDAWgBREeGdLZ3YTEL4CXLvTa8XQRAhRqDAPBgNVHRMBAf8EBTADAQH/MAoGCCqG
SM49BAMCA2kAMGYCMQDv9ZEselgteBlbqOYScKCyVcq3d89zz8Y9GBBB4FXJ3J+q
/h4zDk2Y2IJG63d7Kf0CMQDJl7v9I/NRNtS09qkavJh6snjJvUe3C5RhAkMPDhBO
2sfbUx1UQSo/md6U1CQBewM=
-----END CERTIFICATE-----
Certificate Details:
Subject:
C=US, ST=NC, L=RTP, O=NETAPP, OU=NTAP, CN=scspr2692789021.gdl.englab.netapp.com
Issuer:
C=US, ST=NC, L=RTP, O=NETAPP, OU=NTAP, CN=NTAP-INTERCA2
Expiration: Jan 29 04:46:20 2024 GMT
Certificate Expiration Status: Not Expired
Certificate Revocation Status: good
The example below displays public key information for all 'service-processor' users.
cluster1::> security login publickey show -application service-processor
Vserver: cluster1
UserName: joed Index: 1
Public Key:
ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBFgMRmKHV2+sGDPMD8JdMRS+vSviIyjAymBZ/vu22Ae1AY51RIOBq5cVKaP49O9A21F1Srkqsd3gHFw/UhYBPy8=
Fingerprint:
SHA256:ETxoqJyjq2tXjMKiJlCSTOT5vj+s+h6OxtXUIl28PcI
xiges-husyn-fyzim-sanok-bihos-sizuv-ribyt-cyryz-lelel-sekan-poxyx
Comment:
This is a new publickey
Certificate:
Certificate Expiration Status: -
Certificate Revocation Status: -
