security login publickey show
Display public keys
The security login publickey show command displays information about public keys.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects the public keys that match this parameter value.
 [-username <text>]- Username-
 [-application <text>]- Application-
 [-index <integer>]- Index-
 [-publickey <certificate>]- Public Key-
 [-fingerprint <text>]- Hex Fingerprint-
 [-bubblebabble <text>]- Bubblebabble Fingerprint-
 [-comment <text>]- Comment-
 [-certificate <certificate>]- Certificate Associated with Public Key-
 [-certificate-details <text>]- Details about the Certificate-
 [-certificate-expired <text>]- Expiry Status of Certificate-
 [-certificate-revoked <text>]- Revocation Status of Certificate-
The example below displays public key information for the user named tsmith.
cluster1::> security login publickey show -username tsmith Vserver: vs1 UserName: tsmith Index: 5 Public Key: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAIEAspH64CYbUsDQCdW22JnK6J /vU9upnKzd2zAk9C1f7YaWRUAFNs2Qe5lUmQ3ldi8AD0Vfbr5T6HZPCixNAIza FciDy7hgnmdj9eNGedGr/JNrftQbLD1hZybX+72DpQB0tYWBhe6eDJ1oPLob ZBGfMlPXh8VjeU44i7W4+s0hG0E=tsmith@publickey.example.com Fingerprint: 07:b4:27:52:ce:7f:35:81:5a:f2:07:cf:c1:87:91:97 Bubblebabble fingerprint: xuzom-nelug-bisih-nihyr-metig-kemal-puhut-somyd-mumuh-zomis-syxex Comment: This is a new key Certificate: -----BEGIN CERTIFICATE----- MIICHTCCAaKgAwIBAgIUU+YJjeaOzvs+w+56JSm8Amow0nAwCgYIKoZIzj0EAwIw RTELMAkGA1UEBhMCSU4xCzAJBgNVBAgMAktBMQwwCgYDVQQHDANCTFIxDTALBgNV BAoMBE5UQVAxDDAKBgNVBAsMA1ImRDAeFw0yMjA5MjAwNjAyNDRaFw0yMzA5MjAw NjAyNDRaMEUxCzAJBgNVBAYTAklOMQswCQYDVQQIDAJLQTEMMAoGA1UEBwwDQkxS MQ0wCwYDVQQKDAROVEFQMQwwCgYDVQQLDANSJkQwdjAQBgcqhkjOPQIBBgUrgQQA IgNiAASbaxCYB6XRDOFgdHBghvMoUpideGnd2jNrQJANeSaWVMnPUpXzg2tcPnsu c87AR75BcfwhSurrFGLIw7TLcR22IFTggcrKmhjI8QwvomMZWfIoeHZlwsI+msm4 PLyaCqmjUzBRMB0GA1UdDgQWBBREeGdLZ3YTEL4CXLvTa8XQRAhRqDAfBgNVHSME GDAWgBREeGdLZ3YTEL4CXLvTa8XQRAhRqDAPBgNVHRMBAf8EBTADAQH/MAoGCCqG SM49BAMCA2kAMGYCMQDv9ZEselgteBlbqOYScKCyVcq3d89zz8Y9GBBB4FXJ3J+q /h4zDk2Y2IJG63d7Kf0CMQDJl7v9I/NRNtS09qkavJh6snjJvUe3C5RhAkMPDhBO 2sfbUx1UQSo/md6U1CQBewM= -----END CERTIFICATE----- Certificate Details: Subject: C=US, ST=NC, L=RTP, O=NETAPP, OU=NTAP, CN=scspr2692789021.gdl.englab.netapp.com Issuer: C=US, ST=NC, L=RTP, O=NETAPP, OU=NTAP, CN=NTAP-INTERCA2 Expiration: Jan 29 04:46:20 2024 GMT Certificate Expiration Status: Not Expired Certificate Revocation Status: good
The example below displays public key information for all 'service-processor' users.
cluster1::> security login publickey show -application service-processor Vserver: cluster1 UserName: joed Index: 1 Public Key: ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBFgMRmKHV2+sGDPMD8JdMRS+vSviIyjAymBZ/vu22Ae1AY51RIOBq5cVKaP49O9A21F1Srkqsd3gHFw/UhYBPy8= Fingerprint: SHA256:ETxoqJyjq2tXjMKiJlCSTOT5vj+s+h6OxtXUIl28PcI Bubblebabble fingerprint: xiges-husyn-fyzim-sanok-bihos-sizuv-ribyt-cyryz-lelel-sekan-poxyx Comment: This is a new publickey Certificate: - Certificate Details: - Certificate Expiration Status: - Certificate Revocation Status: -
