security config ocsp disable
Disable OCSP for one or more selected applications
The security config ocsp disable
command disables the OCSP-based certificate status check for applications supporting SSL/TLS communications. For more information about the OCSP-based certificate status check for applications supporting SSL/TLS communications, see the security config ocsp show command.
-application <SSL/TLS Application supporting OCSP>,…
- Application Name (privilege: advanced)-
Use this parameter to specify the application to disable the OCSP support. To disable all applications, the value 'all' can be used. Note: You cannot specify the value 'all' with other applications.
The following example disables the OCSP support for AutoSupport and EMS applications:
cluster1::*> security config ocsp disable -application autosupport,ems cluster1::> security config ocsp show Application OCSP Enabled? -------------------- ------------- autosupport false audit_log true fabricpool true ems false kmip true ldap true ssh true 6 entries were displayed.
The following example disables the OCSP support for all applications:
cluster1::*> security config ocsp disable -application all Warning: OCSP will be disabled for all applications. Any previous modifications will be ignored. Do you want to continue? {y|n}: y cluster1::*> security config ocsp show Application OCSP Enabled? -------------------- ------------- autosupport false audit_log false fabricpool false ems false kmip false ldap false ssh false 6 entries were displayed.
