vserver vscan on-demand-task unschedule
Unschedule an On-Demand task
The vserver vscan on-demand-task unschedule
command unschedules an On-Demand task.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to unschedule an On-Demand task.
-task-name <text>
- Task Name-
This parameter specifies the name of the On-Demand task that you want to unschedule.
The following example unschedules an On-Demand task:
cluster1::> vserver vscan on-demand-task unschedule -vserver vs1 -task-name t1 cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1 Vserver: vs1 Task Name: t1 List of Scan Paths: /test Report Directory Path: /report Job Schedule: - Max File Size Allowed for Scanning: 2GB File Paths Not to Scan: /vol1/cold-files/ File Extensions Not to Scan: mp3, mp4 File Extensions to Scan: * Scan Files with No Extension: true Request Service Timeout: 1m Cross Junction: true Directory Recursion: true Scan Priority: low Report Log Level: verbose
