ONTAP commands
security protocol show
Show application configuration options
The security protocol show command displays the cluster-wide configuration of RSH and Telnet in the cluster in advanced privilege mode. RSH and Telnet are disabled by default. Use the security protocol modify command to change the RSH and Telnet configuration that the cluster supports.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-application <text>] - application (privilege: advanced)
Displays the insecure applications in the cluster.
[-enabled {true|false}] - enabled (privilege: advanced)
Displays whether the application is enabled or disabled in the cluster.
The following example shows the default security protocol configurations for a cluster:
cluster1::> security protocol show
Application      Enabled
rsh             false
telnet          false
The following example shows the security protocol configuration after RSH and Telnet have been enabled:
Application      Enabled
rsh             true
telnet          true
