vserver peer create
Create a new Vserver peer relationship
The vserver peer create
command creates a Vserver peer relationship between two Vservers residing on the same cluster or across two clusters. For intercluster Vserver peer relationships, the cluster administrator must accept or reject the relationship on the peer cluster.
-vserver <vserver>
- Vserver Name-
Specifies the name of the local Vserver.
-peer-vserver <vserver>
- Peer Vserver Name-
Specifies the name of the peer Vserver with which you want to create the Vserver peer relationship.
[-peer-cluster <text>]
- Peer Cluster Name-
Specifies the name of the peer cluster. If this is not specified, it is assumed that the peer Vserver resides on the same cluster.
-applications {snapmirror|file-copy|lun-copy|flexcache}
- Peering Applications-
Specifies the applications for which the Vserver peer relationship is created.
[-local-name <vserver>]
- Peer Vserver Local Name-
Specifies the unique local name to identify the peer Vserver with which you want to create the Vserver peer relationship. The default value is the remote peer Vserver name.
The following example illustrates how to create an intercluster Vserver peer relationship between Vserver lvs1.example.com
, residing on cluster1
, and pvs1.example.com
, residing on cluster2
. The relationship is created for SnapMirror.
cluster1::> vserver peer create -vserver lvs1.example.com -peer-vserver pvs1.example.com -peer-cluster cluster2 -applications snapmirror
, and lvs1.example.com
. The relationship is created for SnapMirror. The -local-name
parameter is specified to create a local name used to identify the peer Vserver in cases where the name of the peer Vserver name is not uniquely referenced from local cluster.
cluster1::> vserver peer create -vserver lvs1.example.com -peer-vserver lvs1.example.com -peer-cluster cluster2 -applications snapmirror -local-name cluster2lvs1locallyUniqueName cluster1::> vserver peer show Peer Peer Peering Remote Vserver Vserver State Peer Cluster Applications Vserver ----------- ----------- ------------ ----------------- -------------- --------- lvs1.example.com cluster2lvs1locallyUniqueName initiated cluster2 snapmirror lvs1.example.com cluster1::> vserver peer show -instance Local Vserver Name: lvs1.example.com Peer Vserver Name: cluster2lvs1locallyUniqueName Peering State: initiated Peering Applications: snapmirror Remote Vserver Name: lvs1.example.com
, and Vserver pvs1
. The relationship is created for SnapMirror. The following Vserver peer permission exists on remote cluster cluster2
for local Vserver pvs1
cluster2::> vserver peer permission show Peer Cluster Vserver Applications ---------------- --------------- ----------------- cluster1 pvs1 snapmirror 1 entries were displayed. cluster1::> vserver peer create -vserver lvs1 -peer-vserver pvs1 -peer-cluster cluster2 -applications snapmirror cluster1::> vserver peer show Peer Peer Peering Remote Vserver Vserver State Peer Cluster Applications Vserver ----------- ----------- ------------ ----------------- -------------- --------- lvs1 pvs1 peered cluster2 snapmirror pvs1 cluster2::> vserver peer show Peer Peer Peering Remote Vserver Vserver State Peer Cluster Applications Vserver ----------- ----------- ------------ ----------------- -------------- --------- pvs1 lvs1 peered cluster1 snapmirror lvs1
Here is an another example which creates an intracluster Vserver peer relationship.
cluster1::> vserver peer create -vserver lvs1.example.com -peer-vserver lvs2.example.com -applications snapmirror
