security saml-sp show
Display SAML service provider for authentication
The security saml-sp show
command displays the Security Assertion Markup Language (SAML) Service Provider (SP) configuration.
The Identity Provider (IdP) URI
indicates the URI of the desired IdP's metadata.
The Service Provider (SP) host
indicates the IP address contaning SAML SP metadata.
The Certificate Common Name
indicates the SAML SP certificate's common name.
The Certificate Serial
indicates the SAML SP certificate's serial number.
The following example displays the SAML SP configuration:
cluster1::> security saml-sp show Identity Provider URI: https://www.my.idp.com Service Provider Host: 1.1.1.1 Certificate Name: mycert Certificate Serial: 1234abcd Is SAML Enabled: false
