security saml-sp show
Display SAML service provider for authentication
The security saml-sp show command displays the Security Assertion Markup Language (SAML) Service Provider (SP) configuration.
The Identity Provider (IdP) URI indicates the URI of the desired IdP's metadata.
The Service Provider (SP) host indicates the IP address containing SAML SP metadata.
The Certificate Common Name indicates the SAML SP certificate's common name.
The Certificate Serial indicates the SAML SP certificate's serial number.
The following example displays the SAML SP configuration:
cluster1::> security saml-sp show
Identity Provider URI: https://www.my.idp.com
Service Provider Host: 1.1.1.1
Certificate Name: mycert
Certificate Serial: 1234abcd
Is SAML Enabled: false
