system switch ethernet polling-interval show
Display the polling interval for monitoring Ethernet switch health
The system switch ethernet polling-interval show
command displays the polling interval used by the Ethernet switch health monitor.
cluster1::> system switch ethernet polling-interval show Polling Interval (in minutes): 40
The example above displays the polling interval period for the switches.
