The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system switch ethernet polling-interval show
PDF of this doc site
Creating your file...
Your file is ready
Display the polling interval for monitoring Ethernet switch health
The system switch ethernet polling-interval show
command displays the polling interval used by the Ethernet switch health monitor.
cluster1::> system switch ethernet polling-interval show Polling Interval (in minutes): 40
The example above displays the polling interval period for the switches.
