system node coredump external-device show
Display a list of files on an external USB device
The system node coredump external-device show command displays basic information about files on an external USB device, such as the filename and size.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -node {<nodename>|local}- Node That Owns the Coredump (privilege: advanced)-
This parameter selects the node that has files that are to be displayed on the external USB device.
 [-device {usb0|usb1}]- Device (privilege: advanced)-
This parameter specifies the name of the external USB device, for example: usb0. Currently, only usb0 is supported. + usb0 refers to the first external USB device connected to the node (regardless of port).
 [-corename <text>]- Coredump Name (privilege: advanced)-
This parameter specifies the core dump file for which the information is displayed.
 [-size {<integer>[KB|MB|GB|TB|PB]}]- Size of Core (privilege: advanced)-
If specified, the command displays information only about the core files that are of the specified size.
The following example displays information about core files stored on external USB devices:
cluster1::> system node coredump external-device show
Node                     Device  Coredump Name
node1                    usb0    core.537051938.2017-10-26.23_52_15.nz
                                   Size: 13074695581 bytes (12.18) GB
