ONTAP commands
system node coredump external-device show
Display a list of files on an external USB device
The system node coredump external-device show command displays basic information about files on an external USB device, such as the filename and size.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
-node {<nodename>|local} - Node That Owns the Coredump (privilege: advanced)
This parameter selects the node that has files that are to be displayed on the external USB device.
[-device {usb0|usb1}] - Device (privilege: advanced)
This parameter specifies the name of the external USB device, for example: usb0. Currently, only usb0 is supported.
usb0 refers to the first external USB device connected to the node (regardless of port).
[-corename <text>] - Coredump Name (privilege: advanced)
This parameter specifies the core dump file for which the information is displayed.
[-size {<integer>[KB|MB|GB|TB|PB]}] - Size of Core (privilege: advanced)
If specified, the command displays information only about the core files that are of the specified size.
The following example displays information about core files stored on external USB devices:
cluster1::> system node coredump external-device show
Node                     Device  Coredump Name
node1                    usb0    core.537051938.2017-10-26.23_52_15.nz
                                   Size: 13074695581 bytes (12.18) GB
