storage path resume
Resume I/O on a path to array
The storage path resume
command continues I/O flow to an array LUN on a path or the entire path that was previously quiesced. It also disables the path failures monitoring feature, if it was enabled using the storage path quiesce`-path-failure-threshold`count
command.
-node {<nodename>|local}
- Node name-
The name of the clustered node for which information is being displayed.
-initiator <initiator name>
- Initiator Port-
Initiator port that the clustered node uses.
-target-wwpn <wwpn name>
- Target Port-
Target World Wide Port Name. Port on the storage array that is being used.
[-lun-number <integer>]
- LUN Number-
Logical Unit number. The range is: [0…65535]. If this parameter is not specified, Data ONTAP resumes the entire path to an array.
The following example resumes I/O between node vbv3170f1b, port 0a and the array port 50001fe1500a8669, LUN 1
node::> storage path resume -node vbv3170f1b -initiator 0a -target-wwpn 50001fe1500a8669 -lun-number 1
