security key-manager external azure restore
Restore missing keys of Azure Key Vault
This command retrieves and restores any current unrestored keys associated with the given Vserver to the nodes internal key tables. This command is not supported when AKV has not been enabled for the Vserver.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver to which the missing keys will be restored.
The following command restores missing keys for the data vserver v1 (which has AKV configuration) to the internal key tables on the cluster.
cluster-1::> security key-manager external azure restore -vserver v1
