The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security key-manager external azure restore
PDF of this doc site
Creating your file...
Your file is ready
Restore missing keys of Azure Key Vault
This command retrieves and restores any current unrestored keys associated with the given Vserver to the nodes internal key tables. This command is not supported when AKV has not been enabled for the Vserver.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver to which the missing keys will be restored.
The following command restores missing keys for the data vserver v1 (which has AKV configuration) to the internal key tables on the cluster.
cluster-1::> security key-manager external azure restore -vserver v1
