volume flexcache origin show-caches
Display all the caches connected to origin
The volume flexcache origin show-caches command displays FlexCache relationships for origin of a FlexCache volumes on the origin cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-origin-vserver <Vserver Name>] - Vserver Name
If this parameter and the origin-volume parameter are specified, the command displays the FlexCache relationship for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays all the FlexCache relationships for all origin of a FlexCache volumes in the specified Vserver.
[-origin-volume <volume name>] - Origin Volume
If this parameter is specified, the command displays all the FlexCache relationships for the specified origin of a FlexCache volume.
[-cache-vserver <vserver name>] - Cache Vserver
If this parameter is specified then the command displays FlexCache relationships for the specified Vserver hosting FlexCache volumes.
[-cache-volume <volume name>] - Cache Volume
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume.
[-cache-cluster <Cluster name>] - Cache Cluster
If this parameter is specified then the command displays FlexCache relationships for the specified cluster hosting FlexCache volumes.
[-cache-volume-msid <integer>] - Cache Volume MSID
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume's FlexGroup master data-set ID.
[-relationship-create-time <Date>] - Relationship Create Time
If you specify this parameter, the command displays FlexCache relationships for which the relationship-create-time option matches the specified input.
[-relationship-type {Intravserver|Intervserver|Intercluster}] - Relationship Type (privilege: advanced)
If this parameter is specified, the command displays the origin of a FlexCache volume matching the relationship type
[-preserve-msid {true|false}] - Preserve Origin MSID on the Cache (privilege: advanced)
If this parameter is specified, the command displays the origin of a FlexCache volume whose Msid is preserved
The following example displays information about all origin of a FlexCache volumes on the Vserver named vs34:
cluster1::> flexcache origin show-caches -origin-vserver vs34
  (volume flexcache origin show-caches)
Origin-Vserver Origin-Volume  Cache-Vserver  Cache-Volume  Cache-Cluster
vs34           origin1        vs56           fc1_c3_origin1
                                                           cluster-3
vs34           origin1        vs34           fc1           cluster-2
vs34           origin1        vs34           fc2           cluster-2
vs34           origin2_new    vs56           fc1_c3_origin2
                                                           cluster-3
4 entries were displayed.
cluster1::> flexcache origin show-caches -origin-vserver vs56 -instance
Vserver: vs56
           Origin Volume: origin
           Cache Vserver: vs56
            Cache Volume: fc1
           Cache Cluster: cluster-3
       Cache Volume MSID: 2156002002
Relationship Create Time: Thu Aug 23 04:36:24 2018
       Relationship Type: intra-vserver
