volume flexcache origin show-caches
PDF of this doc site
Creating your file...
Display all the caches connected to origin
The volume flexcache origin show-caches
command displays FlexCache relationships for origin of a FlexCache volumes on the origin cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-origin-vserver <Vserver Name>]
- Vserver Name-
If this parameter and the
origin-volume
parameter are specified, the command displays the FlexCache relationship for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays all the FlexCache relationships for all origin of a FlexCache volumes in the specified Vserver. [-origin-volume <volume name>]
- Origin Volume-
If this parameter is specified, the command displays all the FlexCache relationships for the specified origin of a FlexCache volume.
[-cache-vserver <vserver name>]
- Cache Vserver-
If this parameter is specified then the command displays FlexCache relationships for the specified Vserver hosting FlexCache volumes.
[-cache-volume <volume name>]
- Cache Volume-
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume.
[-cache-cluster <Cluster name>]
- Cache Cluster-
If this parameter is specified then the command displays FlexCache relationships for the specified cluster hosting FlexCache volumes.
[-cache-volume-msid <integer>]
- Cache Volume MSID-
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume's FlexGroup master data-set ID.
[-relationship-create-time <Date>]
- Relationship Create Time-
If you specify this parameter, the command displays FlexCache relationships for which the
option matches the specified input. [-relationship-type {Intravserver|Intervserver|Intercluster}]
- Relationship Type (privilege: advanced)-
If this parameter is specified, the command displays the origin of a FlexCache volume matching the relationship type
[-preserve-msid {true|false}]
- Preserve Origin MSID on the Cache (privilege: advanced)-
If this parameter is specified, the command displays the origin of a FlexCache volume whose Msid is preserved
The following example displays information about all origin of a FlexCache volumes on the Vserver named vs34:
cluster1::> flexcache origin show-caches -origin-vserver vs34 (volume flexcache origin show-caches) Origin-Vserver Origin-Volume Cache-Vserver Cache-Volume Cache-Cluster -------------- -------------- -------------- ------------- -------------- vs34 origin1 vs56 fc1_c3_origin1 cluster-3 vs34 origin1 vs34 fc1 cluster-2 vs34 origin1 vs34 fc2 cluster-2 vs34 origin2_new vs56 fc1_c3_origin2 cluster-3 4 entries were displayed.
cluster1::> flexcache origin show-caches -origin-vserver vs56 -instance (volume flexcache origin show-caches) Vserver: vs56 Origin Volume: origin Cache Vserver: vs56 Cache Volume: fc1 Cache Cluster: cluster-3 Cache Volume MSID: 2156002002 Relationship Create Time: Thu Aug 23 04:36:24 2018 Relationship Type: intra-vserver
