The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume analytics off
PDF of this doc site
Creating your file...
Your file is ready
Disable collection of file system analytics for a volume
The volume analytics off
command disables file system analytics on a volume.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which file system analytics is being disabled.
The following example disables file system analytics on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics off -vserver vs1 -volume flexvol
