ONTAP commands
volume analytics off
Disable collection of file system analytics for a volume
The volume analytics off command disables file system analytics on a volume.
-vserver <vserver name> - Vserver Name
This specifies the Vserver in which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which file system analytics is being disabled.
[-foreground <true>] - Run Operation in the Foreground
If true, the command doesn't complete until the analytics-state of the volume is off . If false, the command returns immediately, and the analytics-state can be tracked using the volume analytics show command.
The following example disables file system analytics on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics off -vserver vs1 -volume flexvol
