ONTAP commands
network interface service-policy rename
Rename an existing network service policy
The network interface service-policy rename command assigns a new name to an existing service policy without disrupting the LIFs using the policy.
-vserver <vserver name> - Vserver (privilege: advanced)
Use this parameter to specify the name of the Vserver of the service policy to be renamed.
-policy <text> - Policy Name (privilege: advanced)
Use this parameter to specify the name of the service policy to be renamed.
-new-name <text> - New Service Policy Name (privilege: advanced)
Use this parameter to specify the new name for the service policy.
The following example shows the renaming of a service policy.
cluster1::> network interface service-policy show -vserver cluster1
Vserver   Policy                     Service: Allowed Addresses
cluster1
          custom                     intercluster-core: 0.0.0.0/0
                                     management-autosupport: 0.0.0.0/0
                                     management-ssh: 0.0.0.0/0
                                     management-https: 0.0.0.0/0
default-intercluster       intercluster-core: 0.0.0.0/0
default-management         management-core: 0.0.0.0/0
default-route-announce     management-bgp: 0.0.0.0/0
4 entries were displayed.
cluster1::> network interface service-policy rename -vserver cluster1 -policy custom -new-name system
cluster1
          system                     intercluster-core: 0.0.0.0/0
