ONTAP commands
volume efficiency stat
Show volume efficiency statistics
The volume efficiency stat command displays efficiency statistics. The output depends on the parameters specified with the command. If no parameters are specified, the command displays the following efficiency statistics fields for all the volumes:
  • Vserver: The Vserver that the volume belongs to.
  • Volume Name: Name of the volume.
  • Inline Compression Attempts: Number of inline compression attempts done.
  • Inline Incompressible CGs: Number of compression groups that cannot be compressed by inline compression.
To display detailed information, run the command with -instance parameter.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed. The Vserver and volume name are the default fields.
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
Displays statistics only for those volume(s) that match the specified Vserver.
{ [-volume <volume name>] - Volume Name
Displays statistics only for those volume(s) that match the specified volume name.
| [-path </vol/volume>] - Volume Path }
Displays statistics only for those volume(s) that match the specified volume path.
[-b <true>] - Display In Blocks
Displays usage size in 4k block counts.
[-num-compressed-inline <integer>] - Inline Compression Attempts
Displays statistics only for those volume(s) that match the specified number of Compression Groups attempted inline.
The following example displays default efficiency statistics for all the volumes.
cluster1::> volume efficiency stat
Vserver:                       vs1
Volume:                        vol2
Inline Compression Attempts:   0
Inline Incompressible CGs:     0
Vserver:                       vs1
Volume:                        vol3
