security key-manager key query
Display the key IDs.
This command displays the IDs of the keys that are stored in the configured key managers. This command does not update the key tables on the node. Primary key servers, along with any associated secondary key servers, are displayed in the output.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to specify the name of the node that queries the specified key management servers. If this parameter is not specified, then all nodes query the specified key management servers.
 [-vserver <vserver name>]- Vserver Name-
Use this parameter to specify the Vserver for which to list the keys.
 [-key-server <Hostname and Port>]- Key Server-
This parameter specifies the host and port of the key management server that you want to query. This parameter is used only with external key managers.
 [-key-id <Hex String>]- Key Identifier-
If you specify this parameter, then the command displays only the key IDs that match the specified value.
 [-key-tag <text>]- Key Tag-
If you specify this parameter, then the command displays only the key IDs that match the specified value. The key-tag for Volume Encryption Keys (VEKs) is set to the UUID of the encrypted volume.
 [-key-type <Key Usage Type>]- Key Type-
 [-restored {true|false}]- Restored-
This parameter specifies whether the key corresponding to the displayed key ID is present in the specified node's internal key table. If you specify 'true' for this parameter, then the command displays the key IDs of only those keys that are present in the system's internal key table. If you specify 'false' for this parameter, then the command displays the key IDs of only those keys that are not present in the system's internal key table.
 [-key-store <Key Store>]- Key Store-
Use this parameter to specify the key manager type from which to list the keys.
 [-key-user <vserver name>]- Key User-
If you specify this parameter, then the command displays only the key IDs that are used by the specified Vserver.
 [-key-manager <text>]- Key Manager-
This parameter specifies the identity of the key manager. For external key managers that will be the host and the port of the key server. In other cases that will be the name of a corresponding key manager.
 [-key-store-type <Key Store Type>]- Key Store Type-
If you specify this parameter, then the command displays only the key IDs that are used by the specified key manager type.
 [-crn <text>]- Cloud Resource Name-
This parameter specifies the Cloud Resource Name (CRN) of the key. If you specify this parameter, then the command displays only the key IDs that contains such CRN.
 [-policy <text>]- Key Store Policy-
This optional parameter specifies the policy name of the key manager. If you specify this parameter, then the command displays only the key IDs that are associated with the specified policy.
 [-encryption-algorithm <text>]- Encryption algorithm for the key-
This optional parameter specifies the encryption algorithm of the key. If you specify this parameter, then the command displays only the keys of the specified algorithm type.
The following example shows all of the keys on all configured key servers, and whether or not those keys have been restored for all nodes in the cluster:
cluster-1::> security key-manager key query
Node: node1
            Vserver: cluster-1
        Key Manager: onboard
   Key Manager Type: OKM
Key Tag                               Key Type Encryption   Restored
node1                                 NSE-AK   AES-256      true
    Key ID: 000000000000000002000000000001000c11b3863f78c2273343d7ec5a67762e0000000000000000
    Key ID: 000000000000000002000000000001006f4e2513353a674305872a4c9f3bf7970000000000000000
    Key ID: 00000000000000000200000000000100e1f6b27094485d2d74408bca673b25eb0000000000000000
    Key ID: 00000000000000000200000000000100ea73be83ec42a7a2bd262f369cda83a40000000000000000
Node: node1
            Vserver: datavs
        Key Manager: keyserver.datavs.com:5965
   Key Manager Type: KMIP
eb9f8311-e8d8-487e-9663-7642d7788a75  VEK      XTS-AES-256  true
    Key ID: 0000000000000000020000000000004001cb18336f7c8223743d3e75c6a7726e0000000000000000
9d09cbbf-0da9-4696-87a1-8e083d8261bb  VEK      XTS-AES-256  true
    Key ID: 0000000000000000020000000000004064f2e1533356a470385274a9c3ffb9770000000000000000
40c3546e-600c-401c-b312-f01be52258dd  VEK      XTS-AES-256  true
    Key ID: 000000000000000002000000000000401e6f2b09744582d74d084cb6a372be5b0000000000000000
9b195ecb-35ee-4d11-8f61-15a8de377ad7  VEK      XTS-AES-256  true
    Key ID: 00000000000000000200000000000040ea73be83ec42a7a2bd262f369cda83a40000000000000000
Node: node2
            Vserver: cluster-1
Node: node2
            Vserver: datavs
