metrocluster vserver show
PDF of this doc site
Creating your file...
Display MetroCluster Vserver relationships
The metrocluster vserver show
command displays configuration information for all pairs of Vservers in MetroCluster.
[-fields <fieldname>,…]
The command output includes the specified field or fields
[-creation-time ]
(privilege: advanced) -
Shows the last configuration modification time on the Vserver
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-cluster <Cluster name>]
- Cluster Name-
Name of the cluster where the Vserver belongs
[-vserver <vserver>]
- Vserver-
Name of the Vserver
[-partner-vserver <vserver>]
- Partner Vserver-
Name of the partner Vserver
[-configuration-state {healthy|unhealthy|degraded|pending-setup|syncing|replication-paused|pending-switchback}]
- Configuration State-
Configuration states include:
healthy
unhealthy
degraded
indicates that Vservers are not in sync -
syncing
indicates that the Vserver configuration is being synchronized -
replication-paused
indicates that the configuration replication was manually paused -
pending-setup
indicates that partner Vserver creation is pending
[-corrective-action <text>]
- Corrective Action-
Corrective action which can be followed to successfully create the partner Vserver
[-creation-time-of-last-applied-change <MM/DD/YYYY HH:MM:SS>]
- Creation Time on the Source-
Last configuration modification time on the Vserver
[-failed-row <smdb-row-op>]
- Failed Row-
Failed replication row
[-failed-object <text>]
- Failed Object-
Displays the failed object name
[-failed-reason <text>]
- Failed Replication Reason-
Failed replication reason
[-out-of-sync <true>]
- Is Out of Sync-
Indicates that the Vserver configuration replication is not in sync
[-config-resume-time <MM/DD/YYYY HH:MM:SS>]
- Configuration Resume Time-
Displays the resume time of the Vserver configuration replication
[-irrecoverable-apply-failed-reason <text>]
- Reason for Failure-
Reason for the replication failure
The following example shows the output of the command when partner Vservers are created
clusA::> metrocluster vserver show Cluster: clusA Partner Configuration Vserver Vserver State ------------------- ---------------------- ----------------- clusA clusB healthy vs1 vs1-mc healthy Cluster: clusB Partner Configuration Vserver Vserver State ------------------- ---------------------- ----------------- clusB clusA healthy 3 entries were displayed.
The following example shows the output of the command when the partner Vserver creation is pending
clusA::> metrocluster vserver show Cluster: clusA Partner Configuration Vserver Vserver State ------------------- ---------------------- ----------------- clusA clusB healthy vs1 - pending-setup Corrective Action: Create Ipspace ips1 on the partner cluster. 2 entries were displayed.
