metrocluster vserver show
Display MetroCluster Vserver relationships
The metrocluster vserver show command displays configuration information for all pairs of Vservers in MetroCluster.
- { [-fields <fieldname>,…]
The command output includes the specified field or fields
- | [-creation-time ](privilege: advanced)
Shows the last configuration modification time on the Vserver
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-cluster <Cluster name>]- Cluster Name
Name of the cluster where the Vserver belongs
- [-vserver <vserver>]- Vserver
Name of the Vserver
- [-partner-vserver <vserver>]- Partner Vserver
Name of the partner Vserver
- [-configuration-state {healthy|unhealthy|degraded|pending-setup|syncing|replication-paused|pending-switchback}]- Configuration State
Configuration states include: -
healthy
unhealthy
degradedindicates that Vservers are not in sync
syncingindicates that the Vserver configuration is being synchronized
replication-pausedindicates that the configuration replication was manually paused
pending-setupindicates that partner Vserver creation is pending
- [-corrective-action <text>]- Corrective Action
Corrective action which can be followed to successfully create the partner Vserver
- [-creation-time-of-last-applied-change <MM/DD/YYYY HH:MM:SS>]- Creation Time on the Source
Last configuration modification time on the Vserver
- [-failed-row <smdb-row-op>]- Failed Row
Failed replication row
- [-failed-object <text>]- Failed Object
Displays the failed object name
- [-failed-reason <text>]- Failed Replication Reason
Failed replication reason
- [-out-of-sync <true>]- Is Out of Sync
Indicates that the Vserver configuration replication is not in sync
- [-config-resume-time <MM/DD/YYYY HH:MM:SS>]- Configuration Resume Time
Displays the resume time of the Vserver configuration replication
- [-irrecoverable-apply-failed-reason <text>]- Reason for Failure
Reason for the replication failure
The following example shows the output of the command when partner Vservers are created
clusA::> metrocluster vserver show
Cluster: clusA
                                        Partner                       Configuration
            Vserver                     Vserver                       State
            clusA                       clusB                         healthy
            vs1                         vs1-mc                        healthy
Cluster: clusB
            clusB                       clusA                         healthy
            3 entries were displayed.
The following example shows the output of the command when the partner Vserver creation is pending
Cluster: clusA
            clusA                       clusB                         healthy
            vs1                         -                             pending-setup
            Corrective Action: Create Ipspace ips1 on the partner cluster.
        2 entries were displayed.
 PDFs
PDFs
