ONTAP commands
metrocluster vserver show
Display MetroCluster Vserver relationships
The metrocluster vserver show command displays configuration information for all pairs of Vservers in MetroCluster.
{ [-fields <fieldname>,…​]
The command output includes the specified field or fields
| [-creation-time ] (privilege: advanced)
Shows the last configuration modification time on the Vserver
| [-instance ] }
[-cluster <Cluster name>] - Cluster Name
Name of the cluster where the Vserver belongs
[-vserver <vserver>] - Vserver
Name of the Vserver
[-partner-vserver <vserver>] - Partner Vserver
Name of the partner Vserver
[-configuration-state {healthy|unhealthy|degraded|pending-setup|syncing|replication-paused|pending-switchback}] - Configuration State
Configuration states include:
  • healthy
  • unhealthy
  • degraded indicates that Vservers are not in sync
  • syncing indicates that the Vserver configuration is being synchronized
  • replication-paused indicates that the configuration replication was manually paused
  • pending-setup indicates that partner Vserver creation is pending
[-corrective-action <text>] - Corrective Action
Corrective action which can be followed to successfully create the partner Vserver
[-creation-time-of-last-applied-change <MM/DD/YYYY HH:MM:SS>] - Creation Time on the Source
Last configuration modification time on the Vserver
[-failed-row <smdb-row-op>] - Failed Row
Failed replication row
[-failed-object <text>] - Failed Object
Displays the failed object name
[-failed-reason <text>] - Failed Replication Reason
Failed replication reason
[-out-of-sync <true>] - Is Out of Sync
Indicates that the Vserver configuration replication is not in sync
[-config-resume-time <MM/DD/YYYY HH:MM:SS>] - Configuration Resume Time
Displays the resume time of the Vserver configuration replication
[-irrecoverable-apply-failed-reason <text>] - Reason for Failure
Reason for the replication failure
The following example shows the output of the command when partner Vservers are created
clusA::> metrocluster vserver show
Cluster: clusA
                                        Partner                       Configuration
            Vserver                     Vserver                       State
            clusA                       clusB                         healthy
            vs1                         vs1-mc                        healthy
Cluster: clusB
            clusB                       clusA                         healthy
            3 entries were displayed.
The following example shows the output of the command when the partner Vserver creation is pending
Cluster: clusA
            clusA                       clusB                         healthy
            vs1                         -                             pending-setup
            Corrective Action: Create Ipspace ips1 on the partner cluster.
        2 entries were displayed.
