The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume activity-tracking off
PDF of this doc site
Creating your file...
Your file is ready
Disable activity tracking for a volume
The volume activity-tracking off
command disables volume activity tracking on a volume.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which volume activity tracking is being disabled.
[-foreground <true>]
- Run Operation in the Foreground-
If true, the command doesn't complete until the volume activity tracking
state
isoff
. If false, the command returns immediately, and the volume activity trackingstate
can be tracked using the volume activity-tracking show command.
The following examples disable volume activity tracking on a volume.
cluster::*> volume activity-tracking off -vserver vs1 -volume fv1
cluster::*> volume activity-tracking off -vserver vs1 -volume fg1
