      volume activity-tracking off
Disable activity tracking for a volume
The volume activity-tracking off command disables volume activity tracking on a volume.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver in which the volume is located.
- -volume <volume name>- Volume Name
This specifies the name of the volume on which volume activity tracking is being disabled.
- [-foreground <true>]- Run Operation in the Foreground
If true, the command doesn't complete until the volume activity tracking stateisoff. If false, the command returns immediately, and the volume activity trackingstatecan be tracked using the volume activity-tracking show command.
The following examples disable volume activity tracking on a volume.
cluster::*> volume activity-tracking off -vserver vs1 -volume fv1
cluster::*> volume activity-tracking off -vserver vs1 -volume fg1
 PDFs
PDFs
