network options ipv6 show
PDF of this doc site
Creating your file...
Your file is ready
Display IPv6 options
This command displays the current state of IPv6 options for the cluster.
cluster1::> network options ipv6 show IPv6 Enabled: false Router Advertisement (RA) Processing Enabled: false
