The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage firmware acp rename
PDF of this doc site
Creating your file...
Your file is ready
Rename an ACP firmware file
The storage firmware acp rename
command renames the specified ACP processor firmware file on each node.
-oldname <text>
- Old Filename (privilege: advanced)-
This parameter specifies the firmware file to rename.
-newname <text>
- New Filename (privilege: advanced)-
This parameter specifies the new name of the firmware file.
The following example renames the ACP processor firmware file with the name ACP-IOM3.0150.AFW.FVF to ACP-IOM3.AFW.FVF on each node:
cluster1::*> storage firmware acp rename -oldname ACP-IOM3.0150.AFW.FVF -newname ACP-IOM3.AFW.FVF
