ONTAP commands
storage firmware acp rename
Rename an ACP firmware file
The storage firmware acp rename command renames the specified ACP processor firmware file on each node.
-oldname <text> - Old Filename (privilege: advanced)
This parameter specifies the firmware file to rename.
-newname <text> - New Filename (privilege: advanced)
This parameter specifies the new name of the firmware file.
The following example renames the ACP processor firmware file with the name ACP-IOM3.0150.AFW.FVF to ACP-IOM3.AFW.FVF on each node:
cluster1::*> storage firmware acp rename -oldname ACP-IOM3.0150.AFW.FVF -newname ACP-IOM3.AFW.FVF
