cluster controller-replacement network displaced-interface show
Display network interfaces displaced away from this node by controller-replacement
Display logical interfaces that were displaced to another node due to a controller-replacement. A LIF that has been displaced to another node has had its home-node modified to another node because no network ports were available in the same broadcast domain on the original home-node.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- Node
Selects the node from which the LIF was displaced.
- [-vserver <vserver>]- Vserver
Selects the vserver on which the LIF resides.
- [-lif-name <text>]- Lif Name
Selects the name of the LIF for which to display displaced information.
- [-original-home-node <nodename>]- Original Home Node
The original home-node that was assigned to the LIF prior to controller-replacement.
- [-current-home-node <nodename>]- Current Home Node
The current home-node assigned to the LIF after controller-replacement.
The following example displays the displaced LIF information.
cluster1::> cluster controller-replacement network displaced-interface show cluster controller-replacement network displaced-interface show) riginal Current server LIF Name Home Node Home Node --------------- ----------------------- ------------------ ------------------ s0 lif1 node1 node2 1 entry was displayed.
 PDFs
PDFs
