cluster controller-replacement network displaced-interface show
Display network interfaces displaced away from this node by controller-replacement
Display logical interfaces that were displaced to another node due to a controller-replacement. A LIF that has been displaced to another node has had its home-node modified to another node because no network ports were available in the same broadcast domain on the original home-node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- Node-
Selects the node from which the LIF was displaced.
[-vserver <vserver>]
- Vserver-
Selects the vserver on which the LIF resides.
[-lif-name <text>]
- Lif Name-
Selects the name of the LIF for which to display displaced information.
[-original-home-node <nodename>]
- Original Home Node-
The original home-node that was assigned to the LIF prior to controller-replacement.
[-current-home-node <nodename>]
- Current Home Node-
The current home-node assigned to the LIF after controller-replacement.
The following example displays the displaced LIF information.
cluster1::> cluster controller-replacement network displaced-interface show cluster controller-replacement network displaced-interface show) riginal Current server LIF Name Home Node Home Node --------------- ----------------------- ------------------ ------------------ s0 lif1 node1 node2 1 entry was displayed.
