cluster controller-replacement network displaced-interface show
Display network interfaces displaced away from this node by controller-replacement
Display logical interfaces that were displaced to another node due to a controller-replacement. A LIF that has been displaced to another node has had its home-node modified to another node because no network ports were available in the same broadcast domain on the original home-node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node
Selects the node from which the LIF was displaced.
[-vserver <vserver>] - Vserver
Selects the vserver on which the LIF resides.
[-lif-name <text>] - Lif Name
Selects the name of the LIF for which to display displaced information.
[-original-home-node <nodename>] - Original Home Node
The original home-node that was assigned to the LIF prior to controller-replacement.
[-current-home-node <nodename>] - Current Home Node
The current home-node assigned to the LIF after controller-replacement.
The following example displays the displaced LIF information.
cluster1::> cluster controller-replacement network displaced-interface show
cluster controller-replacement network displaced-interface show)
riginal           Current
server          LIF Name                Home Node          Home Node
s0              lif1                    node1              node2
1 entry was displayed.
