vserver fpolicy engine-disconnect
PDF of this doc site
Creating your file...
Terminate connection to FPolicy server
The vserver fpolicy engine-disconnect
command disconnects an FPolicy server from a specified node.
-node {<nodename>|local}
- Node-
This parameter specifies the node that you want to disconnect from the FPolicy server. The value local specifies the current node.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver that you want to disconnect from the specified FPolicy server with the specified attached FPolicy policy.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the FPolicy policy that is attached with an external engine.
-server <IP Address>
- Server-
This parameter specifies the FPolicy server you want to disconnect. The specified server must be present in the external engine configuration of the above specified FPolicy policy.
The following example disconnects an FPolicy server.
cluster1::> vserver fpolicy engine-disconnect -node FPolicy-01 -vserver vs1.example.com -policy-name p -server 1.1.1.1 cluster1::> vserver fpolicy show FPolicy Server- Server- Vserver Policy Node Server status type --------------- ------------- ------------ ----------------- -------------- ----------- vs1.example.com p FPolicy-01 1.1.1.1 disconnected primary
