vserver object-store-server bucket lifecycle-management-rule modify
PDF of this doc site
Creating your file...
Modify a lifecycle management rule
The vserver object-store-server bucket lifecycle-management-rule modify
command modifies a lifecycle management rule for the object store server bucket.
-vserver <Vserver Name>
- Vserver Name-
This parameter specifies the name of the Vserver on which the bucket lifecycle management rule will be modified for the object store server bucket.
-bucket <TextNoCase>
- Object Store Server Bucket Name-
This parameter specifies the name of the object store server bucket for which the lifecycle management rule will be modified. The object store server bucket must already exist.
-rule-id <text>
- Lifecycle Management Rule Identifier-
This parameter specifies the rule identifier of the lifecycle management rule to be applied on the object store server bucket.
-index <integer>
- Lifecycle Management Rule Index-
This parameter specifies the index of the lifecycle management rule to be applied on the object store server bucket.
[-is-enabled {true|false}]
- Is This Rule Enabled?-
This parameter specifies whether the configured lifecycle management rule is to be enabled or disabled on the object store server bucket. The default value when a rule is created is
true
[-obj-age-days <integer>]
- Number of Days since Creation, After Which Current Version of Objects Can be Deleted -
This parameter specifies the minimum lifetime, in days since creation, after which objects can be deleted. This parameter is available for expiration actions only.
[-obj-exp-date <MM/DD/YYYY HH:MM:SS>]
- Specific Date When the Objects Should Expire-
This parameter specifies the expiration date when an object will expire. This parameter is available for expiration actions only.
[-expired-obj-del-marker {true|false}]
- Cleanup Object Delete Markers-
This parameter specifies whether to delete an object that has a delete marker or not. When set to
true
, an object with a delete marker will be deleted. This parameter is available for expiration actions only. - |
[-new-non-curr-versions <integer>]
- Number of Latest Non-current Versions to Be Retained -
This parameter specifies the number of latest non-current versions to be retained. This parameter is available for non-current version expiration actions only.
[-non-curr-days <integer>]
- Number of Days after Which Non-current Versions will Be Deleted-
This parameter specifies the number of days after which non-current versions can be deleted. This parameter is available for non-current version expiration actions only.
[-after-initiation-days <integer>]
- Number of Days of Initiation, After Which Upload Can Be Aborted } -
This parameter specifies the number of days of initiation, after which uploads can be aborted. This parameter is available for abort-incomplete multipart upload actions only.
The following example modifies an object store server bucket lifecycle management rule for Vserver vs1 and bucket1 which specifies expiration action on a set of objects.
cluster1::> vserver object-store-server bucket lifecycle-management-rule modify -vserver vs1 -bucket bucket1 -rule-id rule1 -index 1 -obj-age-days 200"
