The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
event role-config modify
PDF of this doc site
Creating your file...
Your file is ready
Modify role-based event configuration
The event role-config modify
command updates the EMS role-based configuration of an access control role.
-access-control-role <text>
- Access Control Role (privilege: advanced)-
Use this mandatory parameter to specify the access control role for which the EMS role-based configuration needs to be modified.
[-filter-name <text>]
- Event Filter Name (privilege: advanced)-
Use this parameter to specify the new event filter name that needs to be assigned to the access control role.
[-limit-access-to-global-configs {true|false}]
- Limit Access to Global Configs (privilege: advanced)-
Use this parameter to change the limited access to global EMS configurations available with the "event config" commands.
The following examples show the modification of role-based event configurations:
cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events true cluster1::> event role-config modify -access-control-role storage-admin -filter-name storage-admin-events2 cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events2 true cluster1::> event role-config modify -access-control-role storage-admin -filter-name storage-admin-events -limit-access-to-global-configs false cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events false cluster1::> event role-config modify -access-control-role storage-admin -limit-access-to-global-configs true cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events true
