event role-config modify
Modify role-based event configuration
The event role-config modify
command updates the EMS role-based configuration of an access control role.
-access-control-role <text>
- Access Control Role (privilege: advanced)-
Use this mandatory parameter to specify the access control role for which the EMS role-based configuration needs to be modified.
[-filter-name <text>]
- Event Filter Name (privilege: advanced)-
Use this parameter to specify the new event filter name that needs to be assigned to the access control role.
[-limit-access-to-global-configs {true|false}]
- Limit Access to Global Configs (privilege: advanced)-
Use this parameter to change the limited access to global EMS configurations available with the "event config" commands.
The following examples show the modification of role-based event configurations:
cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events true cluster1::> event role-config modify -access-control-role storage-admin -filter-name storage-admin-events2 cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events2 true cluster1::> event role-config modify -access-control-role storage-admin -filter-name storage-admin-events -limit-access-to-global-configs false cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events false cluster1::> event role-config modify -access-control-role storage-admin -limit-access-to-global-configs true cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events true
