volume clone sharing-by-split show
PDF of this doc site
Creating your file...
Show the split flexclone volumes with shared physical blocks
The volume clone sharing-by-split show
command displays the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, this command displays the following information:
Node Name
Vserver Name
Volume Name
Aggregate Name
Volume State
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name (privilege: advanced)-
This parameter selects information about the split volumes with shared physical blocks on this node.
[-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
This parameter selects information about the split volumes with shared physical blocks on this Vserver.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
This parameter selects information about shared physical blocks for this volume.
[-aggregate <aggregate name>]
- Aggregate Name (privilege: advanced)-
This parameter specifies the aggregate associated with the given volume.
The following example displays the split volumes with shared physical blocks in the node:
cluster1::> volume clone sharing-by-split show -node node1 Node Vserver Volume Aggregate --------------- --------- ------------- ------------- node1 vs1 vol_clone1 aggr1
The following example displays information about volume vol_clone1
residing on vserver vs1
cluster1::> volume clone sharing-by-split show -node node1 -vserver vs1 -volume vol_clone1 -instance Node Name: node1 Vserver Name: vs1 Volume Name: vol_clone1 Aggregate Name: aggr1
