volume clone sharing-by-split show
Show the split flexclone volumes with shared physical blocks
The volume clone sharing-by-split show command displays the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, this command displays the following information:
Node Name
Vserver Name
Volume Name
Aggregate Name
Volume State
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node Name (privilege: advanced)
This parameter selects information about the split volumes with shared physical blocks on this node.
- [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)
This parameter selects information about the split volumes with shared physical blocks on this Vserver.
- [-volume <volume name>]- Volume Name (privilege: advanced)
This parameter selects information about shared physical blocks for this volume.
- [-aggregate <aggregate name>]- Aggregate Name (privilege: advanced)
This parameter specifies the aggregate associated with the given volume.
The following example displays the split volumes with shared physical blocks in the node:
cluster1::> volume clone sharing-by-split show -node node1 Node Vserver Volume Aggregate --------------- --------- ------------- ------------- node1 vs1 vol_clone1 aggr1
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split show -node node1 -vserver vs1 -volume vol_clone1 -instance
Node Name: node1
             Vserver Name: vs1
              Volume Name: vol_clone1
           Aggregate Name: aggr1
 PDFs
PDFs
