volume clone sharing-by-split show
Show the split flexclone volumes with shared physical blocks
The volume clone sharing-by-split show command displays the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, this command displays the following information:
Node Name
Vserver Name
Volume Name
Aggregate Name
Volume State
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name (privilege: advanced)-
This parameter selects information about the split volumes with shared physical blocks on this node.
[-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
This parameter selects information about the split volumes with shared physical blocks on this Vserver.
[-volume <volume name>]- Volume Name (privilege: advanced)-
This parameter selects information about shared physical blocks for this volume.
[-aggregate <aggregate name>]- Aggregate Name (privilege: advanced)-
This parameter specifies the aggregate associated with the given volume.
The following example displays the split volumes with shared physical blocks in the node:
cluster1::> volume clone sharing-by-split show -node node1 Node Vserver Volume Aggregate --------------- --------- ------------- ------------- node1 vs1 vol_clone1 aggr1
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split show -node node1 -vserver vs1 -volume vol_clone1 -instance
Node Name: node1
Vserver Name: vs1
Volume Name: vol_clone1
Aggregate Name: aggr1
