ONTAP commands
volume clone sharing-by-split show
Show the split flexclone volumes with shared physical blocks
The volume clone sharing-by-split show command displays the split volumes with shared physical blocks. This command is only supported for flexible volumes. By default, this command displays the following information:
  • Node Name
  • Vserver Name
  • Volume Name
  • Aggregate Name
  • Volume State
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node Name (privilege: advanced)
This parameter selects information about the split volumes with shared physical blocks on this node.
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
This parameter selects information about the split volumes with shared physical blocks on this Vserver.
[-volume <volume name>] - Volume Name (privilege: advanced)
This parameter selects information about shared physical blocks for this volume.
[-aggregate <aggregate name>] - Aggregate Name (privilege: advanced)
This parameter specifies the aggregate associated with the given volume.
The following example displays the split volumes with shared physical blocks in the node:
cluster1::> volume clone sharing-by-split show -node node1
Node            Vserver   Volume        Aggregate
node1           vs1       vol_clone1    aggr1
The following example displays information about volume vol_clone1 residing on vserver vs1 :
cluster1::> volume clone sharing-by-split show -node node1 -vserver vs1 -volume vol_clone1 -instance
Node Name: node1
             Vserver Name: vs1
              Volume Name: vol_clone1
           Aggregate Name: aggr1
