volume move abort
Stop a running volume move operation
The "volume move abort" command sends an abort message to the volume move operation and returns immediately. The volume move operation might not abort immediately depending on the stage it is in. For example, if the volume move operation is in a cut-over or clean-up phase, the abort is ignored. You invoke the "volume move show" command to view the list of running volume move operations and monitor the progress of the abort operation. This command has the same behavior as the job stop-id
<job-id>
command where the job-id is the identifier of the volume move job.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume being moved.
The following example aborts running volume move operation on volume vol1
cluster1::> volume move show Vserver Volume State Move Phase Percent-Complete Time-To-Complete --------- ---------- -------- ---------- ---------------- ---------------- vs0 vol1 alert cutover_hard_deferred 0% - vs0 vol2 failed failed - - 2 entries were displayed. cluster1::> volume move abort -vserver vs0 -volume vol1 cluster1::> volume move show -vserver vs0 -volume vol1 -fields completion-status vserver volume completion-status ------- ------ -------------------------- vs0 vol1 "Volume move job stopped."
The following example shows command failed to abort on vol2
as volume move operation is completed.
cluster1::> volume move show Vserver Volume State Move Phase Percent-Complete Time-To-Complete --------- ---------- -------- ---------- ---------------- ---------------- vs0 vol1 alert cutover_hard_deferred 0% - vs0 vol2 failed failed - - 2 entries were displayed. cluster1::> volume move abort -vserver vs0 -volume vol2 Error: command failed: There is no volume move operation running on the specified volume.
