The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock event-retention abort
PDF of this doc site
Creating your file...
Your file is ready
Abort an Event Based Retention policy operation.
The snaplock event-retention abort
is used to abort an ongoing Event Based Retention (EBR) operation. This command only aborts the operations that have not yet completed. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
Specifies the vserver on which the EBR operation is running.
-operation-id <integer>
- Operation ID-
Specifies the operation ID of the EBR operation that needs to be aborted.
The following example aborts an ongoing EBR operation with operation-id 16842754
vs1::> snaplock event-retention abort -operation-id 16842754 vs1::>
